well if you are getting over fueling..... maybe its not all staying in the intake system....... what pressure does the air get up to once the butterfly closes? have you leak tested your piping to 40psi and listened for leaks at that pressure? your clamps and joins might hold fine at 14psi but are they holding the sudden spike? is any of that air blowing back past the turbo and venting out the low pressure clamps where crank pressure goes? is some of that pressure making it out back out the AFM for a moment?
Is some of that pressure going down and getting past the idle air control valve?
In the quick moment that it spikes you don't actually know whats happening with that extra pressure, some cars were designed from the factory and dont run BOV, the S15 on stock ecu was designed with a BOV.
with a BOV you know exactly where that pressure spike is going to vent around too
