So it started with a hesitation when I pressed the accelerator. Then it progressed to having a rough idle when warmed up. The idle was fine when cold but its now a bit rough when cold as well. The main problem now is that when I have the throttle just open to try and cruise along in whatever gear, the car starts to sputter and run like ****. The car revs up ok (seems to be down on power though) but just as I try to hold the revs at a certain point it all goes to sh*t. When the car is stationary and out of gear, and the throttle is opened, the same happens; it revs fine but can't hold the revs in any one place without starting to sputter and stutter like crazy. At first I thought it was the AFM because when the car was idling rough if I plugged out the AFM it idled ok when warm. Tired cleaning it several times and then replacing it.
I've replaced the following:
Spark plugs
Lambda/O2 sensor
Air Flow Meter/Mass Air Flow Sensor. Did this twice with 2 seperate 2nd hand units that I was assured were both in good working order.
Cleaned the throttle body and intake plenum down with throttle body cleaner
Replaced the fuel filter under the bonnet
I've also inspected the spark plug cables and they're fine. The distributor seems to be ok as well, little bit of corrosion but nothing major as far as I can see.
Few questions:
Should I invest in a brand new AFM or would it be a waste of money? Does it sound like an AFM issue?
Should the inside of my intake plenum be very sutty/black with dust? (because it was and I'm a bit worried)
Should i try cleaning the injectors with a fuel additive?
Does it sound like a fueling issue or air flow issue?
And finally: WHAT THE F**K IS WRONG WITH MY CAR!? Because i'm fit to throw a brick through the window at this stage!
Any help appreciated!
Spark plugs
Lambda/O2 sensor
Few questions:
