Nickichi
- 13 March 2010
- Southampton, UK
- forum.s15oc.com
Heya
I probably know the answer to this but i thought i would try here first (and boost my count lol, been a while)
I've been working on the front of the car trying to remove rust that has built up since the awful winters we've had for a while in the UK and when I got to the pulley after removing the fan I thought oh sh*t.
My initial idea was to use either the anti rust gel to clean it or use a dremal tool to grind it off but looking at it in the pic's, it looks like it is in a pretty bad state and im not sure if grinding will work (may even upset the balance).
I'm thinking now I'm gonna remove all the pulleys so i can see what they are like behind them and unless grinding will work I'm thinking it might just be easier to get a new oem part for the main pulley and respray it so it would last a bit longer than with the normal coating. The other pulleys I can replace with the GReddy versions except for the AC compressor which again could be cleaned/replaced and resprayed to resist the rust better.
Whats ur thoughts guys & girls?
