Washer bottle, motor and pipes? Is it legal to drive without those in Australia? Removing the spare won't effect the*
handling enough for you to notice.*
Reducing weight means less luxury. Add into the equation that you want to improve handling, braking etc.*
Seats change to lighter save at least 10kg per side. Lowers centre of gravity.*
Removing rear seats, stereo, speakers, rear seatbelts, carpet, ac, and the rest blah blah.*
Your requirements to keep interior stock is harder.*
Anything in engine bay that you can replace with carbon or lighter alloy.*
Lighter panels, carbon or aluminium: bonnet, wings, bootlid, bumpers etc. Wanna look stock? Spray it all.
Lighter wheels. Stock weighs a ton.*
Lighter exhaust. Stock weighs a ton. *
Change to lighter suspension. Stock sus is heavy!
Alloy radiator
Flywheel
Prop-shaft
You can spend much money and still think if you just replace your seats and remove rear seats you'd save an instant 20kg easily.*
Spoon saved 100kg on their S2000 by replacing every nut and bolt with titanium items.*
If you want to "add" lightness you must lose stuff.*
My 2p worth.
