will this offset fit S15...
sushiming
13 November 2005
Hong Kong
hey guys seen some work emotions for sell they came off a RX8 and the fittment is 18 X 8.5 + 43
will they fit or not.....
Justified
S15
16 6.5 +45 Stock
16 7 +29 Recommended by Taka Kaira
16 7 +33 Front Recommended by Rays/Nismo
16 7 +35 Recommended by Work
16 8 +38 Recommended by Taka Kaira
16 8 +45 Rear Recommended by Work
17 7 +30 Recommended by Taka Kaira/Rays/Nismo
17 7 +31 Recommended by Work
17 7 +35 Recommended by Work/Rays
17 7.5 +30 Front Recommended by Rays
17 8 +38 Recommended by Taka Kaira/Rays/Nismo
17 8 +44 Rear Recommended by Rays
17 8 +45 Rear Recommended by Work
17 8.5 +40 Rear Recommended by Rays
18 7.5 +30 Front Recommended by Rays
18 7.5 +31 Recommended by Taka Kaira
18 7.5 +32 Recommended by Work
18 7.5 +35 Recommended by Work
18 8 +36 Recommended by Taka Kaira
18 8.5 +40 Rear Recommended by Rays
18 8.5 +45 Rear Recommended by Work
silviac
Justified said:
S15
16 6.5 +45 Stock
at the end, it all comes to the tyre size.
I am running with 17 8 front and back both with 38
but for front i have 225 and for rear i have 235 tyres.
I have to run 5mm spacer on the front to match with guard.
It is ok to leave it just like that but I want the maximum looking :cool:
so I guess when the wheels chosen then the tyre size must be chosen carefully
Difficult to say. Going to depend on how they sit. And if you intend changing you supsension and lowering. 225s is a good bet for front. 245, maybe 255 for back. I've got the same question with mine. And the offset isn't as good...
Justified said:
S15
....17 9 +10 SpecS15
I have 17x9j's with +17 offset, 215 fronts, 225 rears. Would +10 not make them stick out even further?? as they are already out past the arch.
Nice choice of wheels :thumbs: :D
Meddy
Topper said:
Justified said:
S15
Have you got wide front arches mate? When I tried 17 * 9's with a 19 offset on mine they stuck out about 1 inch past the outer edge of the arch.
Nope, when i got the car it was running a fair chunk of camber, but with that corrected the wheel stick out 15-20mm from the arch :) The tyres are streched so the tyre is under the arch but the wheel aint :p
sushiming
13 November 2005
Hong Kong
so the wheels ive seen on ebay are perfect really?
so aslong as i get the right tyres should be ok
what about 225 front and 235 rear??
