It works best as a recirculative BOV. I had issues with the aftermarket ones and getting the spring tension right. To tight,it was over fueling on closed throttle, to soft and it was leaking boost under WOT.why? ^^
mine has a adjustable spring tension, so you can slow the return right down, but its probably causing boost leaks....Cheers spoony! Mine has been mapped with the BOVTA so I will leave it. Please as you say the staggered release is entertaining!
