Weard noises and premiture detonasion
R
Rosscoss
How can i solve this? My engine is prety much standard. I have a Greedy Boost controler, Blitz Induction filter, and a cat back Exhust systum.
Also there is a funny noise like a rattely leaky sound while under Acceleration, also letting off Acceleration and while keeping at the same speed. What could this be and meen? Hope somone can help cause i want my power back as i have ternd the boost right down on low boost but the noise is still there the same as it was befor. Thanks Ross :thumbs:
R
Rosscoss
Here is the Boost controler i have on my car.
Here is the problem with the Dump valve spiting oil
Hope it's not anything bad so hope somone can help :thumbs:
That is what I was thinking, especially with the oil coming out of the BOV
sx-si
7 June 2008
hampshire uk
it looks like its either piston rings or compressor side of your turbo (inlet) ive seen it a few times
also seen a bodge using a catch tank- air mod
if you have a catch tank take off the pipe that runs from right hand side (middle) oif the cam cover block the lower part off and use the top to go the the catch tank then leave the other whole on the catch tank open (to air) and it should be a good tempary fix.
that apparently works on if the exhaust is smoking on de-acceleration
also your best off doing a wet and dryt compression test just to make sure its not pistons
It's obvious that your blow off/dump valve is venting to the atmosphere.
Because its on your hot pipe close to the turbo it is picking up your blow by oil and blowing it out the vent on the side of the dump valve.
I'd put a catch canister on and see how it goes
Check your turbo to manifold bolts aren't lose,its a common problem the turbo comming loose ;)
R
Rosscoss
Hi thanks for everyones help. Sorry i have been working so much lately. I don't have an oil catch tank so can't be that. whats the most likely cause? Turbo seals? :thumbs:
