vvt rattle
B
brianjj14
i have got vvt rattle in my sr20de,so what do i need to get to get rid of it:confused:asap
B
brianjj14
i unplugd the solnoied and the noise is stil there,isnt it supose to go when i unlplug it if its the soilnoied???
23 July 2010
SW London
Unplugging the solenoid disables it completely. The vvt runs off oil pressure which is fed by the solenoid, so if it's not opperational it will rattle constantly.
It may be a faulty solenoid, but it could also be the sprocket itself. They're not hard to change, if it is the sprocket, you just need to make sure you time the cams up properly. The easiest way is to mark up the chain with the sprockets so you don't lose the original timing.
B
brianjj14
have you done this? If so how much did it cost you?? If you have any other info like how to test the solenoid,or where to get these parts. Thanks
