Urgent question re heat wrap
Paddy
i've just spent the last hour and a bit wrapping my type 2 minifold in heat wrap... started her up and after a min or two, white smoke started coming from the wrap. turned engine off and stood gaurd with extinguisher. is this normal burning in process or should i be very concerned?
Cheers Paddy
Paddy
phew... nice 1 mate... should i go out and rally it for a little while or just leave it run for few mins??
27 April 2006
Ireland
just let it run for a bit, no rallyin needed lol did you do the turbo elbow while you were at it?
Paddy
cool...
yeah bought the elbow at the same time as the manifold and i forgot to get heat wrap (which was smart :) ), elbow wasnt a great fit wit the factory front pipe, heard blowing and smelled exhaust gases, and the heat out of the manifold was mental. got a new front pipe and decat and heat wrap all at the same time to cut the costs and fix all the probs. i only got it fitted today during work and the heat wrap went on after i got home. hopefully i get a bit of performance now that my engine bay temps arent going to be so high!
gunner93
Normally the heat wraps should be soaked in water for a while to soften the material. This is to get a snug fit around the pipes. Its normal to get a burnt smell the first time you run it.
also makes your hands itch... it's like fibre glass... horrible stuff! lol
Paddy
How hard would it be to do the frontpipe in-situ, lying on the floor :wack: :D
Really easy! :wack: just jacked it up. once you get past the elbow it's just loops.
I got the whole manifold, elbow and half the front pipe in one go, no cutting :thumbs:.
Yeah, itchy stuff... i think that it has metal flakes or something in it, felt as if i had splinters all over, in my eyes and mouth too! :hurl:
Paddy
i got it from someone in the west of ireland... probably not the most convenient for you tho... 10 meters did an exhaust, elbow and half the front pipe, but i was a bit wasteful with it.
Cool, i'll try get some, plan to do the Frontpipe at the moment, maybe the elbow at a later date.
Paddy
Should probably do the two at the same time... the elbow would be a little hotter then the front pipe and might need it more... plus they're right next to each other! :nod:
The sensor port on the elbow makes it really handy to locate the first loop of the heat wrap too
