Turbo Seals going? whats the best fix? New Turbo?
james s15
he guys, think I have my problem solved
Loosing boost when hot
oil spray coming from the Blow off valve
Am i looking at having to get a new turbo?
If so what should I look at getting, any links you can post will help
cheers James
13 April 2009
australia
if your handy you could buy a rebuild kit and i know there's threads floating around on forums with instructions on how to rebuild them or just upgrade
23 July 2010
SW London
If you're leaking oil into the intake system a, ''service kit'', isn't going to help you much as oil leakage means something is worn internally. Fitting standard sized parts into a worn system is asking for trouble. If you've got the rollerbearing core there's not much you can do. Garrett stopped the release of cores a couple of years ago, stock is limited everywhere.
The company I work for supplies them for £537+vat but there's no warranty with them, even though they're genuine Garrett.
