Couldn't find an answer to this, s15 elbows seem to be few and far between so when going aftermarket which is the correct one to fit out of the s14 and s14a elbows? I understand the 14a elbow is a little longer but that's it.
In NZ a dump pipe is the bit that comes off the turbo im assuming thats what you brits call a elbow?, a front pipe is the bit after that, the its the cat, then cat back.You've lost me spoonman - How come the elbows are sold as either S14 or S14a specific..? My understanding is there is difference in angle and length between the two types, and the matching downpipe has to be used otherwise the rest of the exhaust becomes malaligned..?
if you need to bridge a 6mm gap between the existing flanges are are too afraid to cut and weld, just buy another flange and bolt it in between the two pipesCheers chris, Yeah I knew the two had to be matched up (14-14, 14a-14a), same with the decat being different lengths, my downpipe's an HSD dual for an S15. So I'm just wanting to make sure I definitely have the correct elbow (currently S14) so I don't put too much stress on anything connected to it. There weren't any real issues when fitting, apart from a small gap of maybe 6mm between the decat and tail pipe, it but just want to be 100% sure.
You've lost me here, the S14 and S14a are the exact same car, just cosmetic changes in the external appearances, bonnet, headlights, rear tail lights. Why would Nissan change the angle of the downpipe when at the time they were only criticised for the look of the car.You've lost me spoonman - How come the elbows are sold as either S14 or S14a specific..? My understanding is there is difference in angle and length between the two types, and the matching downpipe has to be used otherwise the rest of the exhaust becomes malaligned..?
Both exhaust from turbo back are exactly the same, you can even put it on an S15 if you cut 10mm out of it in the rear...
right about now, i would like to offer my services to weld you all up a custom exhaust system..... shame about the being on the other side of the world, buy yourself's a welder... honestly learn to mig and tig it will blow you mind...... and if a purchased item does not line up exactly just make it fit.....
also just to keep your guys guessing..... when you run a aftermarket manifold.... what do you think that will do to your exhaust position? keep everything in the exact same place? himmmmm my high end jap made tomei manifold lifted my turbo system by 12mm... so what did i do, got the grinder and welder out and extended the front pipe, (the on before the cat) another 12mm to suit so the entire system was not rubbing on the body, it altered the entire system position that the rear muffler was too close to the rear bumper..... what to do about that.... cut and weld, cut and weld, cut and weld
keep in mind that if you run a stainless exhaust manifold, once red hot your position of everything after will move slightly.....
anymore S14 S14A S15 exhaust specific talk, or oh no what do i do talk, and ill chalk up my pimp slapping hand and bitch slap you
