O
old_s13
Subframe Help / old_s13 Restoration Project
Hi guys, I've posted a few times in the past but usually not relating my car. This time, I need some help and I am hoping someone can chime in with some good info.
I spent many many hours searching for information and pics, I wasnt able to find too much.
I have an US-spec S13 Hatchback here in the States, obviously, and its currently undergoing a very very... very lengthy restoration. Everything was stripped, repainted, and upgraded.. from chassis to undercarriage. Its also updated to widebody with bubble flares.
With that said, I'm currently working on the subframe & suspension arms. I've managed to locate Nismo bushings for almost everything. However, I've been tossing the idea back and fourth in whether or not to go with S15 subframe. So far here is what me and the boys on Zilvia.net have confirmed:
- its stronger and beefier
- it can bolt on with the use of eccentric solid aluminum bushings
- its wider ~10mm i believe
- it has a built in rear brace, it appears to be welded onto the subframe
- it has better anti-squat suspension geometry
since finding one used is a pain in the ass and expensive to ship, i should be able to import it through my local nissan dealer.. only catch is i have to buy it brand new, which isnt too unrealistic.
one thing i would like, if possible, is if you guys can post pics of your undercarriage or in specific, of the s15 subframe. i noticed there arent many pics on the forum. if you guys can please share some pics, that would be a great help.
thanks!
thanks!
