Jono
On Monday I decided to re-fit the negative battery terminal to my battery, as when I fitted a grounding kit a few weeks back, I'd not secured the clamp as robustly as I'd have liked.
Anyway, full of the joys of a sunny bank holiday monday morning, I set to with a 10mm spanner and started to undo the clamp on the +ve terminal. What happened next... can you guess?
Yes, foolishly I had not thought of disconnecting the -ve terminal first and when the spanner came into contact with an earthing point I received a nasty shock. Worse still - the spanner was in contact with my gold engagement ring which I wear on my right hand. The ring heated up to such a temprature that it melted itself to my finger... the skin on my finger burst open like a banana skin right down to the flesh and there I was, left screaming in the street trying to pull the damn thing off my finger.
48hrs later it looks exactly like this... The picture doesn't do it justice believe me.
The ring was a 4-band puzzle ring, the sort that come apart... that's been nicely fused together, and the celtic pattern it made when assembled has been well and truly b*ggered as well. Gutted.
Suffice to say, it hurt quite a lot. I can safely say, I'll not do that again! :wack:
