starter motor help
17 February 2012
Southwest, UK
I have a feeling it's located under the intake manifold. Not 100% as I'm working from my poor memory.
That is correct, it is below the plenum,just where 2 heater hoses come from the block near the firewall. If you look at your clutch slave cylinder just look straight down from there to the bell housing
21 July 2008
Essex/London
Changed this earlier in the year, right pig. You have to remove a load of bracing on the intake manifold to make your life easier.
