Has anyone here ever fitted, or is knowledgable (sp?) about fitting a stack dash to an s15. Things that had me concerned are
Wiring up the warning lights like ABS, Airbag, main beams, diff warning light, etc.
Wiring up the speedo as it takes its feed from the diff on the s15, would this cause problems?
If removal of the dash cluster would cause a failure in another part of the system? For example in the s13 if you remove the cluster the diff cooler wont work because it has a switch to only come on over ten miles an hour which is triggered from in the cluster electronics.
If anyone can help on any of these issues or knows of another reason why it could cause problems i'd be grateful for your help.
