FS: Sr20det bare engine
4 August 2011
Standard unopened sr20det with approx 115k miles. Occasional vvt rattle but nothing too bad. £850ono collected from Taunton Somerset or plus P&P (will wrap it to a pallet)
Sounds sweet as the video below will show, I'll do a compression test before removing from the car.
If you're quick then you can see it running in the car :)
<object width="560" height="315"><param name="movie" value="//www.youtube.com/v/TbJfmFnsegs?version=3&hl=en_GB&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/TbJfmFnsegs?version=3&hl=en_GB&rel=0" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
The price above is for the bare block with no ancillaries although plenum, standard injectors, alternator and PAS pump can be included for the right price :)
4 August 2011
Forgot you can't embed videos on here :(
here re is the vid http://youtu.be/TbJfmFnsegs
ive also got a full stage 3a bolt on package to suit the engine (s14a ecu) gt2871r turbo, Forge adjustable actuator, z32 afm with custom elephants trunk and plug, apexi air filter (meant for standard afm but works ok), nismo 555cc injectors, apex manifold and elbow and all braided lines. £1450 This will be available after the engine is out the car :)
More parts available http://www.sxoc.com/vbb/showthread.php?573814-Breaking-H-dev-stage-3a-s14a-Green-lots-of-nice-bits
