You'd need specR cas, injectors, coilpacks, harness and ecu. Other specS parts would work no problem As Far As I Know...
As I'm in need of it, did you get the harness from another specR or from a shop?
p.s. you'll also need spec R maf (z32 would be best) as in some occasions ecu fuel cut may occur (it did happen on mine)
