- 21 February 2009
- netherlands
- www.xsh-tuning.nl
Just wanted to show you all my new mazworx RB28 engine!
Ready to put in one of my s15's
[FONT=Verdana, sans-serif]-RB28 Stroker Engine Specs:[/FONT]
[FONT=Verdana, sans-serif]Engine:RB26DETT[/FONT]
[FONT=Verdana, sans-serif]Bore:86.5mm[/FONT]
[FONT=Verdana, sans-serif]Compression:10.5:1[/FONT]
[FONT=Verdana, sans-serif]Stroke:79mm[/FONT]
[FONT=Verdana, sans-serif]Rod Length:4.783[/FONT]
[FONT=Verdana, sans-serif]-Mazworx RB25/26 79mm Billet Crankshaft
-Custom CP Pistons (set of 6)[/FONT]
[FONT=Verdana, sans-serif]-Headgasketower Enterprise 88mm 1.1[/FONT]
[FONT=Verdana, sans-serif]-Carrillo Connecting Rods RB25/RB26, Pro-H, WMC Bolts[/FONT]
[FONT=Verdana, sans-serif]-ACL Race Rod Bearing Set[/FONT]
[FONT=Verdana, sans-serif]-ACL Race Main Bearing Set[/FONT]
[FONT=Verdana, sans-serif]-ARP Main Stud Kit[/FONT]
[FONT=Verdana, sans-serif]-GReddy Oil Pump BNR32/BCNR33/BNR34[/FONT]
[FONT=Verdana, sans-serif]-Greddy GTR Oil Pan Extension [/FONT]
[FONT=Verdana, sans-serif]-RB26DETT N1 Water Pump [/FONT]
[FONT=Verdana, sans-serif]-Gasket Set, RB26DETT [/FONT]
[FONT=Verdana, sans-serif]-ARP Head Studs, RB26 [/FONT]
[FONT=Verdana, sans-serif]-ATI Super Damper R32 RB26DETT [/FONT]
[FONT=Verdana, sans-serif]-Clean and R/R Oil Ports [/FONT]
[FONT=Verdana, sans-serif]-Bore & Hone w/ Torque Plate [/FONT]
[FONT=Verdana, sans-serif]-Resurface Block [/FONT]
[FONT=Verdana, sans-serif]-Resize Line Bore [/FONT]
[FONT=Verdana, sans-serif]-Assemble Short Block, Provide Spec[/FONT]
[FONT=Verdana, sans-serif]-Weld Oil Pan Extension and Remove AWD Diff[/FONT]
[FONT=Verdana, sans-serif]-Supertech Intake Valve, +1mm, RB[/FONT]
[FONT=Verdana, sans-serif]-Supertech Iconel Exhaust Valve,[/FONT]
[FONT=Verdana, sans-serif]-Supertech Valve Guide, Exhaust,[/FONT]
[FONT=Verdana, sans-serif]-Supertech Valve Guide Intake Nissan SR20DET/RB26 6 mm stem Manganese Bronze[/FONT]
[FONT=Verdana, sans-serif]-Supertech Dual Valve Spring, 92in/82ex lbs on the seat[/FONT]
[FONT=Verdana, sans-serif]-Supertech Titanium Retainer, RB26 [/FONT]
[FONT=Verdana, sans-serif]-Supertech Exhaust Valve Stem Seal, SR20DET (ea)[/FONT]
[FONT=Verdana, sans-serif]-Supertech Intake Valve Stem Seal, SR20 (ea)[/FONT]
[FONT=Verdana, sans-serif]-Kelford Racing Cams, RB26, High RPM Turbo, 280[/FONT]
[FONT=Verdana, sans-serif]-Tomei Adjust Pulley RB26/RB25/RB20[/FONT]
[FONT=Verdana, sans-serif]-Tomei ADJUST PULLEY RB26/RB25/RB20 EX[/FONT]
[FONT=Verdana, sans-serif]-GReddy Timing Belt, RB20/RB25/RB26[/FONT]
[FONT=Verdana, sans-serif]-Competition Valve Job [/FONT]
[FONT=Verdana, sans-serif]-Resurface Head [/FONT]
[FONT=Verdana, sans-serif]-R/R Valve Guides [/FONT]
[FONT=Verdana, sans-serif]-RB Quench Pad Removal [/FONT]
[FONT=Verdana, sans-serif]-Stage 2 Port and Polish, Gasket Match, Bowl Work, Blend and Polish[/FONT]
[FONT=Verdana, sans-serif]-Assemble/Shim (Solid Pivots), Provide Spec Sheet[/FONT]
[FONT=Verdana, sans-serif]-Assemble Longblock/Degree Cams [/FONT]
[FONT=Verdana, sans-serif]Turbo/manifold/exhaust specs:[/FONT]
[FONT=Verdana, sans-serif]-Garrett GTX4294R 1.30a/r[/FONT]
[FONT=Verdana, sans-serif]-Tial Outlet Flange GT42 [/FONT]
[FONT=Verdana, sans-serif]-Tial Inlet Clamp GT42 [/FONT]
[FONT=Verdana, sans-serif]-Tial Outlet Clamp GT42[/FONT]
[FONT=Verdana, sans-serif]-Mazworx RS Topmount T4 Turbo Manifold RB20/25/26[/FONT]
[FONT=Verdana, sans-serif]-2x Tial MVS[FONT=Verdana, sans-serif] Wastergate's[/FONT][/FONT]
:wave:
:wave:
