How much power are you running in your s15? I have 210rwkw and the s15 goes well in all gears with next to no lag. But compared to a stock s15; yes - the rx7 (a good one) is noticably faster in all gears.
To the OP - the key is to understand how a Rx7 has to be modified; it's not like other cars where exhaust and intake mods don't require an ECU upgrade. Even just a full turbo back exhaust is enough to require an ECU change on a Rx7 to be safe. An SR20DET or 4G63 will tolerate some detonation without exploding on the first sign - it won't like it; but it won't die. One ping on a rotary and it will keel over in a screaming heap.
The rx7 is really a car for enthusiasts who are die hard rotary fans and who know what is required to run them well. For someone who wants a fast car but doesn't want or know all the intricacies of the Rx7 - then a Silvia / Evo / Skyline is the answer. The people who have been burned by buying a poorly modified Rx7; or who have dabbled in modification only to have to rebuild one or more times belong in the latter group.
The problem in NZ at least is that the unknowing masses have pretty much butchered most of the Rx7's here with crap bodykits; cheap single turbo conversions; backyard rebuilds etc. Finding a nice tight unmolested example is near impossible.
If you go the Rx7 route, find a nice one and either leave it stock; or modify it properly and thoroughly from the start. If done right, they can be relatively reliable - it's just that many aren't (done right). Just do your homework first and if it stacks up; then get one and enjoy it
I really liked the Rx7 for a long time (I still do somewhat); I just don't have the patience / can't justify the expense in owning one knowing what's involved. Especially when a well modified s15 can do it all. You have to more than LIKE an Rx7 to be a happy owner... you have to LOVE them.
I do love my S15 though... that's why you should buy one
