- 12 December 2006
- London
- www.silivaoc.com
- @silviaownersclub
Hi all
Thank you for taking a moment to read my issue with my car
My car is currently not registering anything on the RPM gauge/tacho. I have not had a chance to check with an alt-meter if the signal is correct from the ECU as I'm not sure which wiring to check.
The car is running a chipped ECU (standard ECU chipped).
There is a strange white wire which was crimped to a white/purple wire on the dash harness and has a label in Japanese saying "Warning, Do not cut this wire" - unfortunately someone has already got to it as I found it connected to.. nothing.. behind the head-unit. There is a small capacitor/resistor which is in the little box in the picture - the box is labled "s sens" - I'm guessing for - Speed Sensor.
I've attached some images in case anyone knows what it is for and if it is related
Many thanks
Joeh
Many thanks
Joeh
