FS: S15 Parts forsale, Injectors 480cc, Inlet gaskets, turbo gasket
Having a small clear out
Forsale
S15 turbo 480cc injectors cleaned and flow tested and never used since.(Bought as spares) New top and bottom Orings, in great condition. With pintles all good! £125 posted
Genuine Nissan gaskets
both top and bottom inlet manifold gaskets, iacv gasket, throttle gasket= £35posted for all (will split £20posted for inlet gaskets, £10 for iacv, £10 throttle)
Genuine Nissan turbo to exhaust manifold gasket £10 posted
Genuine Nissan Sr20det injector Orings top and bottom £12posted
Apex Front camber bolts 14mm. Allow adjustment of camber on the shock mounting, helps with wheel clearance (add positive camber at shock to move wheel lip away from Spring, then reduce camber on top mount) £20 posted
