tooley
When only sideways will do!
Thought we should start an alignment thread. All be it for Daily to Drift to Racing etc. Thought it would be good to see what people have used / tried.
Drift Alignments
Measurements are in degrees' and minutes" (not . of a degree!) For example - 1'30" is ONE DEGREE AND 30 MINUTES, NOT one point three degrees.
Before alignment, check your tyre pressures! 32PSI front and 40PSI rear is a good start point.
Traction links are set at standard length for these settings.
If you over centre the steering too much, then reduce the castor angle. This applies to all settings.
THESE SETTINGS ARE BASED ON THE S14 / S15 PLATFORM. They should work with S13 variants with a touch less castor for each.
TOE SETTINGS ARE PER SIDE.
STREET / DRIFT / DAILY
FRONT
camber 2'50"
castor 7'30"
toe 0'00"
REAR
camber 1'10"
toe 0'00"
RESULT:
Positive steering feel
Will not grab or snap
Stable and consistent control
MINIMAL STREET / DRIFT USE
FRONT
camber 2'50"
castor 7'30"
toe 0'05" OUT
REAR
camber 1'10"
toe 0'10" IN
RESULT
Stable but reactive steering
Strong rear end grip, will push you forwards
Stable, but needs accurate driver input.
JAPANESE STYLE DRIFT ONLY
Using a trackday tire on the front (123 Radial, AD08, V70A, R888, RSR, etc... no not FK452, R1R)
FRONT
camber 3'20"
castor 7'30"
toe 0'15" OUT
REAR
camber 1'10"
toe 0'10" IN
RESULT:
Front end bites on drift
Understeer without commitment to drift
FAST direction change
WESTERN STYLE DRIFT ONLY
FRONT
camber 3'20"
castor 6'50"
toe 0'05" OUT
REAR
camber 0'30"
toe 0'10" IN
RESULT
Flat grip level, consistent to drive
More driver steering input required
Much more grip out of corners
Reduced aggression in car
More power required
Stats taken from Mitto's thread on DW.
I have ran all of these at some point and I alternate between them depending on what track.
My last setup was a modified version of Western style
FRONT
camber 3'20"
castor 7'30
toe 0'05" OUT
REAR
camber 0'50"
toe 0'10" IN
This worked quite well for big tracks but a 3.6 ratio diff is not recommended. Upgrade to a 3.9 Ratio minimum.
Drift Alignments
FRONT
camber 2'50"
castor 7'30"
toe 0'00"
REAR
camber 1'10"
toe 0'00"
RESULT:
FRONT
camber 2'50"
castor 7'30"
toe 0'05" OUT
REAR
camber 1'10"
toe 0'10" IN
RESULT
FRONT
camber 3'20"
castor 7'30"
toe 0'15" OUT
REAR
camber 1'10"
toe 0'10" IN
RESULT:
FRONT
camber 3'20"
castor 6'50"
toe 0'05" OUT
REAR
camber 0'30"
toe 0'10" IN
RESULT
More power required
FRONT
camber 3'20"
castor 7'30
toe 0'05" OUT
REAR
camber 0'50"
toe 0'10" IN
