"Ruggers" ps13 with an s15 engine
R
Rocket
Finally got my car home so i could start work on it ...
the car had a misfire and would not run properly foot down in second 20mph :eek:so i thought it could be a air leak after the afm so i checked everything and found the dump valve not connected to anything. Put it back together and still had the same problem. I also took off the erg , carbon canister and removed the air con. I then checked the fuel tank and it was full of rust and the pump its self was all rusted up so I went and got a load of fuel and chucked in my walbro pump and all is good ....
on the out side its got some scars that need mending so ive got the fibre glass out and the filler and im mending the front bumper as half of it is missing
Im changing the inside of the car round a bit it has a purple material dash (which im keeping:rotfl:) but the surrounds were painted white and looked awful so they have been replaced
