Not sure if this is normal but i recently changed to a FMIC and Forge re-circ, now when the engine is warm it idles at about 800 rpm but causes quite a bit more vibration through the car, almost as if its idling too low. Ive adjusted the idle speed screw by 1 turn which has helped but is this normal when changing to a FMIC or different BOV/Re-circ or have i now got a gasket blowing (doesnt sound abnormal when driving and no noticable loss of boost) ?
* - Btw its not a coil issue as i recently replaced 1 faulty coil so i know what its like running on 3 cylinders.
