rear wiper help
21 March 2009
westhmeath ireland
was thinkin about geting rid of the rear wiper and motor
because i never uses it
is there a bit you can get to fill the hole in the glass
thanks for the the help lads:thumbs:
29 May 2009
ireland
go to ur local motor factors dey av loads ov grommets wi diff sizes-i de-wipered mine givs a real smooth look.think d hole is 31mm or so also use silcone just 4 peace ov mind
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
well that was hard to read, however through the txt talk I think I have managed to work out your suggesting him to buy a normal grommit and use silicone. If its the right size, silicone isnt required.
and I suppose you haven't been introduced to the forum rules.
9. Please refrain from using Txt 5p33k or slang - We expect a good level of English to be used and posts to be clearly written. This includes using words like m8, wud, da, dat and sum1 etc. This is very much an international forum that has many users where English isn't their native language so please bear this in mind before posting. Any posts using an excessive amount of nonsense words will be deleted and the user given a warning. Any further excessive use will result in the user being subject to the forum disciplinary process
