Rear Wheel Bearing and hub nut parts code needed.
25 October 2009
oxford
Does anyone know or know where i can find the nissan parts number for the rear wheel bearing and hub nut. I find myself in a bit of a dilema atm so any help wd be most appricated. O and found out that that the s14 hub nut is not the same as the s15 one for future reference for anyone.
Cheers Alan
djmasterg
Try that (that is what was on a box with rear wheel hub and bearing from nissan dealer):
43210-AA100
Hope that will help. Greg.
25 October 2009
oxford
Yer thx for pointing that out greg,
The reason i'm after the parts code for a new bearing is because I think i fooked the wheel bearing as i tried pulling it off with a hub puller and didn't suceed. when i finally did get it off using a different method theres now loads of play in the bearing. from what i can tell the inner race of the bearing is made of too halves and i think on using the puller i moved one half away from the other. If i was to press the to halves together would it put things right or will i have to go to the trouble of sourcing a new bearing? any surgestions would be most appricated.
djmasterg
Hi
That will be only mine opinion : so If I were you, I would just get new wheel hub (might cost you over 130Pounds and that's the only thing telling you not do it). But on the other hand - new hub is giving you 100% assurance that your wheel wont fall off the car. When it comes to hub and bearing and other parts - cannot tell you anything. I just swapped my old hub and bearing with new hub and bearing.
