radio aerial help
21 March 2009
westhmeath ireland
trying to get radio stations in my car but not to sure
why its not working where is the aerial on the s15 is it built into the back window or sumthing:wack:
japmadlad
28 June 2007
Armagh, N.Ireland
have you got the standard jap headunit that came in the car? If so you need a band expander to pick up stations here. Not sure were the aerial is in the S15. Normal head unit from here don't need anything & should work fine.
Theres a built in signal booster that you may need to add a power source to get it working as they seem to stop when you change head units. Theres plenty of threads about it if you have a search.
