SR2O
Hey Guys,
I've recently acquired an R33 GTR - diff, half shafts, and axels (6 bolt) for the S15. I have not come across anything online regarding what needs to be done to retain the ABS system using the new R33 GTR diff.
In the R33 GTR, two ABS sensors from the diff are used to provide a signal through a single harness plug. The S15 uses one ABS sensor through to a single harness plug.
So the question, which scenario am I in? :
A) The ABS sensor harness from R33 GTR diff plugs straight into the S15 harness and provides the corrent signal for S15 ABS module.
B) The ABS sensor harness from the R33 GTR diff required modification to harness plug and/or signal for the S15 ABS module
C) The R33 GTR diff centre and half shafts need to be frankenstiened with the S15 diff to retain ABS
D) Other scenario
Appreciate your help guys, apologies if this is covered somewhere but damned if I can find it!
D) Other scenario
