Power FC issues
B9NKO
5 December 2010
Midlands
I've got an apexi power fc on my car and it dosnt store my settings, everytime I turn the ignition on and off it just resets, the boost setting is always the same as it's only got 1 map on it but if I set the monitor display to 8 channels then turn the ignition on and off the back light goes back to being dim and it goes back to 1 channel and just shows the boost?? Does anyone know how to resolve this??
Thanks
I would be checking for blown fuses as mentioned above
B9NKO
5 December 2010
Midlands
The thing is it dosnt reset completely as when I disconnect the battery it loads up with the serial number and what engine it's for (sr20det) but when I turn the ignition on and off it loads straight up with the boost setting, it did this in the car I removed it from aswell??
