power fc identification
4 February 2017
gloucestershire
hi all,
i have recently imported an s15 and it had a few more goodies on than i was expecting.
now it has an apexi power fc on it.
it runs a z32 maf but i have also found a denso 3bar map sensor and a fast acting IAT sensor.
now what style ecu is it L-jetro or D-jetro??
serial number is SR205 0003 -0013
i do apologise if this has been covered but i couldnt find anything,
any help is much appreciated.
20 November 2013
Essex
map sensor for boost control?
i don't that much about mapping but would imagine you can run either or, so i would make sure the Z32 is plugged in and i would imagine you should be able to access the read out from the AFM from the ECU controller?
4 February 2017
gloucestershire
Thanks for the input.
It has the extra boost control kit on it also. Just can't understand why it would run maf and map and have the iat sensor.
Also can't find any information about that serial numbered ECU
drifter
4 April 2011
Norfolk
Looks like these are the 3 S15 versions...
414-AN018 regular
414-N024 D-Jetro
414-N009 Pro version (Discontinued)
