mine has just packed up and im wondering what the cause could be? Do they go often and last but not least where can i get a replacement? will the s15 motor fit?
back to basics cheack relays switchs and fuses first befor thinking the worst. if you have already then i am unsure were to get one but if its fooked try phil at driftworks as he is running lexan windows in his now so he might have a spare
Don't hear about them going that often, but its a motor and can happen. S14 and S15 motors are different. They are also three different S15 part numbers depending on age. If necessary, you can get a replacement from Perfectrun. Usual 4-7 days.
cheers for the info, ive just stripped it and the brushes that create the current are worn, dont look like they can be replaced tho. Any chance you have the part no for a 2002 model?
