i believe, my car is still overboosting. the defi' is peak warn at 1bar... and i sometimes see that flash when goin' for it.
basically, i'm running just the actuator straight off the hotpipe. no EBC.
I thought it could be a faulty standard actuator, so i've changed that, and now have a HKS adjustable.
The arm on it, is as long as it can be, without the wastegate being completely open.
So, i guess, what i'm basically askin' is, what's the lowest amount of boost that can be run on the HKS actuator?
the gauge appears to be just wobbling which is causing the peak to flash, but still,... i'd rather have the actuator boost lower, and then bring it up with the EBC!
cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
cheers
