Jap Style
Hey people,
I thought I would put up my pride and joy to show everyone and see what you all think of it.
Its a 1999 Nissan JDM Silvia S15
ENGINE:
Bored, honed, machined and chem cleaned block
Fully balanced bottom end
Ross harmonic balancer
Crack tested and chem cleaned crank
ACL race bearings
Eagle 3D H-heam rods with ARP bolts
CP 86.5mm pistons
ARP main & head stud kits
Nissan oil & water pumps
Nissan gasket kit
Nissan timing chain kit
Full port & polished head
Tomei 1mm head gasket
Tomei 260in/270ex procams
Tomei adjustable cam gear
Tomei 1mm oversized valves
Tomei valve guides
Tomei solid pivot/lifters
Tomei type B dual springs & retainer
Tomei rocker arm stoppers
Airbrushed rocket cover & fuel rail
Ikeya formula intake plenum
Ikeya formula quad throttle bodies
Ikeya formula fuel rail
Siemens injectors
Garrett GT3582R turbo
Tial v-band rear housing
Greddy manifold (modified)
HKS turbo heat shield
HKS GT-II 50mm wastegate
Custom screamer dump
Trust LS front mount intercooler
Trust 13 row oil cooler kit with remote mount
Trust oil cap
Trust sump
Fwin dual layer radiator
SFS radiator hoses
Split fire coil packs
MagnaFlow fuel regulator
SpeedFlow fittings & braided lines
Nismo engine mounts
Greddy pully kit
Garage defend GT cooling panel
Custom air box/radiator overflow/ oil catch can setup
K&N air filter
Trust dump and front pipe
Trust petir titanium cat back
Apexi evc
Nismo intake fuel pump
Custom 2.5L surge tank
Bosch 044 pump
DRIVE TRAIN:
Nismo 6 speed gearbox
ORC twin plate clutch
ORC lightened flywheel
Nismo GT LSD
Trust diff cover
WHEELS:
Volk 57s pro
Front 18 x 9
Rear 19 x 9.5
Trust wheel nuts
BRAKES:
R33 GTR brake master cylinder BM57
FRONT
Trust front 6 pot calipers
Trust 355mm rotors
Trust pads
Trust braided lines
REAR
R33 drum handbrake conversion
Trust 4 pot calipers
Trust 330mm rotors
Trust Braided lines
ELECTRONICS:
Haltech platinum PS1000 ECU
Haltech IQ3 display dash
Defi control unit 2
Defi boost gauge
Defi oil temp gauge
Defi oil pressure gauge
Defi exhaust temp gauge
Greddy incabin damper control
SUSPENSION:
Greddy type S coilovers
Nismo front strut brace
Nismo rear strut brace
Nismo front lower control arms
Nismo rear lower control arms
Nismo front sway bar
Nismo rear sway bar
Uras front cast rods
Tein tie rods
Cusco rear camber arms
Cusco rear toe arms
Uras rear subframe bushes
BODY:
Full Vertex lang kit
House of kolor white with white candy
Front and rear guards flared
Yashio factory led tail lights
F1 style side mirrors
Custom airbox ram duct
INTERIOR:
Bride zeta 3 seat's
Bride SL seat rails
Bride door trims, roof lining & centre console
Custom RedBull dash
GT1 Motorsports boss spacer
Nardi deep corn steering wheel
Nismo gear knob
4point rollcage
Alpine 6.5in DVD player
Boston amplifier
Boston speakers
The engine I have only just finished getting rebuilt so I have yet to have it all back up and running. But let me know what you think so far.
I will be sure to update with my progress.
Matt
ENGINE:
ACL race bearings
CP 86.5mm pistons
Nissan gasket kit
Tomei valve guides
Siemens injectors
Trust oil cap
Trust sump
SFS radiator hoses
Nismo engine mounts
Greddy pully kit
K&N air filter
Apexi evc
Bosch 044 pump
DRIVE TRAIN:
Nismo GT LSD
Trust diff cover
WHEELS:
Volk 57s pro
Front 18 x 9
Rear 19 x 9.5
Trust wheel nuts
BRAKES:
FRONT
Trust 355mm rotors
Trust pads
Trust braided lines
REAR
Trust 330mm rotors
Trust Braided lines
ELECTRONICS:
Defi control unit 2
Defi boost gauge
Defi oil temp gauge
SUSPENSION:
Nismo rear sway bar
Tein tie rods
Cusco rear toe arms
BODY:
INTERIOR:
Bride zeta 3 seat's
Bride SL seat rails
Custom RedBull dash
Nismo gear knob
4point rollcage
Boston amplifier
Boston speakers
Matt
