Just seen this
Fuel wise, I'm running a massive Mazworx -10an fuel rail, with a Sard FPR, 1000cc injectors and the Aeromotive stealth fuel pump. I am at the point where injector duty is a problem, main reason for this is size of the supply pipe from the pump to the FPR/rail. My plan is to replace the smaller Sard FPR with an Aeromotive -6an jobbie, bigger fuel lines from the pump and change the rail so that it's fed from both ends with a centre return. That should cure any starvation to the rail, and make the supply more even. I've also hard wired the pump to make sure it gets max voltage. I could just up the pressure, but it might not make a difference if there's not enough fuel flowing.
Re the engine, the one thing I regret the most after having my engine built was not installing liners. To be fair though, I never intended to go this far
I wouldn't go bigger diameter pistons, stick to normal oversize. If my engine does fail for any reason, it WILL be getting a full 2.2ltr stroker kit though
If you want 500bhp then go for the GTX3071 with the smaller housing and it'll be pretty responsive. Mine is mapped to 8000rpm on hydraulic lifters, but with a full Ferrea valve spring kit to stop valve bounce. It doesn't stop pulling.....ever
If you wanted a bit less have a look at the GTX2867 as it could be just the job for a fast response mid 400bhp
