Oil Pressure guage.
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
It seems to be reading backwards!!!!
Its wired correctly.
ive used my old sender not the one from the new gauge so im assuming that might be it. it could be reading a different resistence value. Guess ill have to put the new sender on.
Anyone come accross this before?.
27 April 2006
Ireland
Ive seen it when the wires are the wrong way round on the sender or the gauge. What model and make is the gauge and sender that youre using?
tooley
10 October 2009
ive only got one wire for the sender. ita a greddy sender with a cheap guage atm untill i get my sard ones from rhd japan.
29 September 2008
London
i had a problem with mine when i first hooked it had only one cable (red) from the sender and i had two cables to connect one to the sender (red) so other is earth so earthed it with earths to the back of the engine but gauge didnt work probably so changed the earth directly to the sender using a juplie clip to clamp the earth around the barrel of the sender working perfectly now.
martinbattye
the calbration and the operation of a sender not designed for a certain gauge will be miles out even if it did work in the correct manner...
swop out to your proper sender
tooley
10 October 2009
Yea i did that the other day its working fine now. Thanks anyway.
Just thought since the greddy is better quallity i should stick to that. Didnt realise that the calibration would be that different.
