If you go for leccy fans you'll need a fan controller too which will have a temp. sensor built in, sarting the fans at a preset temp 80 C..? Your stock thermostat should open at 76.5 C anyway, so in theory this wouldnt make any difference, but if you have fans kicking in at 80ishC then you may have the fans battling against the stock thermostat.
Its a shame there isnt a was of adjusting when the stock elec fan kicks in. It would be a lot easier to add another one in, than mess around with fan controllers etc.
The standard single elec fan which is hidden away against the rad kicks in at 95 C and off at 90 C which some people say is fine, but others say is a bit high, but the viscous should keep it below that (if fitted).
