New owner from UK
E
Emperor
hi all,
just got my s15 spec s a week now.
drives very good and comfort. hop can meet some people here and share some information of the 15.
my car have a small problem, it is the standard oil pressure gauge, sometimes its work but not always.
can anyone tell me how to fix it / where should i look at?
thank you very much.
Welcome pal :) I can't help you with the gauge but I'm sure someone on here will help you out..
Nearly posted 'what standard oil pressure gauge'. Then I read you had a Spec S. Spec S specific stuff is a bit of a mystery to most people due to their rarity. I'd suggest checking the connector in the pod first, then try to find the pressure sensor and check that.
E
Emperor
THANKS mate,
so you are saying there not many spec S in UK? well i got one now, if you want me to looking into any details or post up and photo please give me a shout.
i did check the plug at the back of the gauage, all good. the pressure sensor was a bit tricky, cause it hide behind the engine block to in-let manifold brace, my hade cant get into there. :(
regards
Until recently, it was impossible to bring in the Spec S after the rules changed in 2004. More are coming through now though. It's more the technical details which are a mystery, as there is no Spec S workshop manual in English.
Yes, the location for fitting oil pressure/temp sensors is generally a complete PITA to get to on the SR20. The filter is also a pain too. This is possibly why, if your sensor has gone, the last owner never bothered fixing it. It's much easier to access it from underneath when the car's on a ramp.
