Hi Guys..
My s15 started life as a non spec R so I haven't got the pillar boost gauge. So when I bought the car the lad had a crappy ebay one installed in the middle centre air vent, which didn't work. So from recommendations from this site I went for the Motor Metter Racing Black face gauge. (in the wrong size though but that's my fault, I got a 52mm but needed the 60mm ).
Now I'm not sure if I'm doing something wrong, as it won't read the boost, all it dose is just pulse from 0.2 to 0.8 even if its off or on boost.
I had to run a new pipe in as I couldn't find the original one, so I ran it into the engine bay and there was already a cut with a joint so I just used that. The pipe I used was the same pipe the boost controller uses, and I get a reading no problem on that.
So if anyone can work out what I'm doing wrong from that, I'd appreciate it.
Thanks
Thanks
