All parts collected from Witney, Oxfordshire, can post at extra cost.
Best to whatsapp me for pics 07790665573
[FONT=.SF UI Text][FONT=.SFUIText]S15 spec R cluster/clocks £200[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Pro lite autometer/shift light £20[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Pro comp oil pressure gauge £70[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Hks evc boost controller £300[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Revotec water temp sensor £20[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 cas bracket £40[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 cas £80[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 uprated coilpacks £100[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 power steering pump £100[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Hks fcon pro gold, with fcon navigator, RB26 loom and ecu £600[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 standard valve springs £80[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 tomei type b springs, brand new in box £360 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]RB26 hks 264 cams, exhaust love has some pitting £100[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Defi guages with control meter and sensors, oil pressure, oil temp, fuel pressure and water temp £500[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Q45 throttle body with adaptor plate £200[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S14 Custom downpipe back exhaust £300[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]SSR stitch evolution wheels, 18x9.5/10 et5 £1400[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Passenger side 14a headlight £80[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Extra front lock set up, subframe with moved steering rack, superpro poly steering rack bushes, tein inner and outer tie rods, modded knuckles no hub/bearings, extended lower arms with new ball joints and polybushs £300[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Spare pair of front knuckles with no bearing/hub, brake holes drilled to 19mm £60[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Rear polybushed knuckles with r33 skyline drum handbrake, no discs, new wheel bearings 500 miles ago, brand new Nissan wheel studs £250 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]front cusco lower tension arm brace £50[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Driftworks adjustable front tension rods £80 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S15 standard rear lights, drivers side is damaged but may be of some use £60[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S15 uras rear bumper £180[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Momo course gear knob £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Braided lines from abs pump to front brake's join £20[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]FET turbo timer £20 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText] S14/SR Power steering lines £20[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Cusco s13 front tension arms £40 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Nats 2 siren £10 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Elbow for fmic £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S14 black passenger seat £20[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S14/sr power steering pump £40 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]S13/ca power steering pump £40[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]2x 295-35-18 Pirelli sottozero w 240 tyres £100[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]14a subframe boomerangs £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Pair of standard bonnet hinges £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Standard boost controller £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Battery tie down bar £5 [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Brand new sr20 slave cylinder £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]2x rear subframe white line pineapples £5[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Sr20 dipstick and tube £10[/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Standard length steering rack gators bnib £10[/FONT][/FONT]
[FONT=.SF UI Text]
[/FONT]
[FONT=.SF UI Text]
[/FONT]
