LuPix's Track & Drift Project
Finally got my baby home!!
Picked it up from Torque GT yesterday and had a nice long drive back. The test drive last week only gave me a small taster. Now I've had a chance to really put it through it's paces and it really is an awesome machine!!
My mate who came to collect the car with me (and owns a Supra TT) kept commenting on how smooth the power delivery was throughout the entire rev range :D
Spec List ** Updated 13-10-10 **
Year 2000 Model (BB Turbo)
A'PEXi Induction Filter
A'PEXi Power FC (L-Jetro & hand controller)
Apex Performance Type 2 FMIC
HKS SSQV (without recirc)
HKS Turbo Timer
HKS Silent Hi-Power (middle box removed)
Japspeed Turbo Elbow
Japspeed Downpipe
Japspeed Decat Pipe
Japspeed 50mm Alloy Rad
Japspeed 12" Electric Fans x2
Nismo Oil Filler Cap
Nismo Rad Cap
Gizzmo MS-IBC Boost Controller (max 1.2 bar)
Apex Performance Braided Turbo Coolant Hoses
Apex Performance Braided Turbo Oil Hose
Driftworks Thermostatic Oil Cooler
Blue Silicone Vacuum Hoses
Blue Lightweight Anodised Pulleys
Replica Garage Defend CF Slam Panel
EP Racing CF Spark Plug Cover
NGK Iridium Spark Plugs
Walbro 255 Fuel Pump
Exedy Hyper Twin Plate Clutch & Flywheel
Defi Link Control Unit II
Defi Link Display Unit (oil temp/pressure & water temp)
Defi BF 60mm Boost Gauge
Tein Super Street Coilovers (with pillowball top-mounts)
Tein Strut Brace
Driftworks Tension Rods
Subframe Alloy Locking Collars
17x8 +29 & 17x9 +37 SSR Professor (custom cherry centres)
215/40 & 245/40 R17 Avon ZZ3
25mm Hubcentric Spacers (front & rear)
K-Sport 330mm 8 Pot Front Brake Kit
K-Sport Brake Pads (front)
Ferodo DB2500 Brake Pads (rear)
Ferodo DOT 5 Brake Fluid
Nismo GT Shift Knob
Driftworks Handbrake Button
Handbrake Handle Grip
CF Centre Console
CF Door Handle Cards
CF Door Sill
CF Switch Panel
Bride Digo Type R Seat
TRS 4-Point Harness
HKB Steering Wheel Boss
C-One Buckskin 50mm Offset Steering Wheel
Ignition Kill Switch
Fire Extinguisher
Works9 Front Bumper (custom quick release brackets/bolts)
Front GT Splitter (custom with adjustable tie rods)
Front Wide Fenders (+20mm)
Rear Wide Fenders (+50mm)
Driftworks CF 3D Rear Wing (custom ali struts & CF end plates)
Driftworks Racing Tow Hooks
RE-Amemiya Pro Replica Rear Diffuser (custom fitted)
SPA GT Race Mirrors (fitted with custom CF base plates)
6000K HID Kit
Nismo Indicators (smoked)
Yashio Factory LED Rear Light Units (smoked)
Latest pics:
Older shots of her in action
Cheers - James :)
Thanks for the pos feedback :thumbs:
The Kakimoto zorst is LOUD - and it's only cat-back :eek:
Is it normal for Silvia's to pop like crazy when driving at low speeds? Since I've picked up the car, when changing from 1st to 2nd and sometimes into 3rd, it's popping nearly everytime I lift off to change gears.
The neighbours aren't going to like this... :rotfl:
sushiming
13 November 2005
Hong Kong
its really nice buddy i like it
i dont like the lip on the white ones but looks pretty good on blue:thumbs:
24 February 2006
Plymouth
Looks class dude!!! :cool:
Now change those wheels!!! the colour of them is good... but dont like the spoke pattern! :whip:
7 January 2007
Perth, Wait Awhile
Nice! You might wanna do something bout ur zorst, the way your zorst is pointing, the rear pods will melt in no time. Especially if your trashing it.
And the popping is due to running rich. If u shift below 0psi on the boost gauge, it wouldnt pop. It only pops if u shift around 0 or near 0. Are you running atmo bov?? If you are, then probably that's why it's running so rich.
Can you please try what mileage ur full tank can do. Mine the best I can is 380km which is pretty bad for an s15. I've yet to solve the running richness. I've researched around and it's either the atmo bov or the o2 sensor is dead.
Good luck and have fun!
Ichi - thanks for the advice :thumbs:
Yes - the car is fitted with a Blitz Super Sound Dump Valve. I have read stuff about when all the air is vented etc, the fueling continues as normal hence the lost air makes it very rich.
However, I am getting really good mpg on the car.
The day I collected it, I had to drive it back 200 miles door to door from the importers. The first thing I did down the road was to fill the tank to full with V-Power.
After 200 miles - it only used half the tank :)
Ok, a lot of it was motorway miles but surely I'm assuming I can get at least 350 miles / 560 km on a full tank?
