Lost in translation
Have to love the Japanese English translation of text...
[h=2]
[/h]
  • ■The limited model which pursued total performance.
  • ■It is exclusive design classified by type of each car with carbon intake duct.
  • ■K&N four layers wet cotton filter adoption.
  • ■The maintenance can make long life works.
[h=2]The intake system of a carbon duct that ideal air intake was pursued.[/h]In fact ,original is surely.
But original position can not become perfect,because they have to think about limited cost for their production.
In consideration of efficiency,to top priority without being influenced by the restrictions inhalation air content and the rectification effect.
RAM AIR SYSTEM is top of intake system which has best quality for material of duct and all fittings.
[h=2]Designed for the flow of air.[/h]If the air design has got power at all through combustion for engine,the relation by air can not be bypassed.
As you know if temperature is lower has the high density of oxygen,serves as fuel-air mixture and burns,air can get high performance and high torque.
You know making it inhale direct,while neither garbage and dust has passed many air filters makes a big risk involved to engine and another parts.
But it serves as resistance at the time of inhalation,and sometimes serves as hindrance of the combustor efficiency on the efficiency of combustion.
K&N has cleared this conflicting theme by adopting the wet filter made from a cotton of four layers built in long history.
About the flow of velocity and temperature at the time of one inhalation,it is adopting conic filter shape,and when air passes a filter,it succeeds in making the flow of velocity raise.
And the limited space in engine room is used as effectively as possible,and the inhalation course of air is intercepted nearly completely with engine with the intake duct made from carbon.
And the shape of the intake duct is designed so that it may all be calculated and the flow of velocity may rise step by step with ram pressure.
The air intake kit can make the real performance not only the shape and many test & try which there is not with how often and is repeated based on outstanding filter and correct data.
[h=2]
[/h][h=3]
[/h]
The high density multi layer cotton by K&N which dose not need to be told any longer and which is excellent in the dust collecting effect is adopted as the centering cone shape filter it self. All carbon cases is designed for each car character. It is hard to be influenced with the intake duct made from carbon which intercepts heat by heat,and filling efficiency controls the performance decrement of stability and progress,and a high load continuation air intake by leaps and bounds by more over the flow velocity at the time of inhalation having been raised by shape design of the filter part.
And the performance decrement of a high load continuation air intake is controlled.
[h=3]
[/h]
All carbon duct made by hand with light weight.
And it is strong for high pressure intake air.
But that best shape of design is different from type of car model in limited engine room size.
This special carbon intake duct can make best air flow with ram pressure and it brings enough chamber effect at peak power.
Also we always take care of carbon finish of this kit.
it is important not only performance but also looks.
[h=3]
[/h]
All kits excellent bolt on fitting with the exclusive design of fitting adapter.
It is same as genuine intake kit with correct fitting. with carbon duct.
GruppeM RAM AIR SYSTEM kit has correct fitting adapter and all stuff in their kit for best instruction,so anyone can install this kit.
The each parts can make highest performance.
Installation is easy with bolt on kit.
There is case by type of car to take out bumper when their install.
[h=3]
[/h]
A serial license plate is fixed to GruppeM RAM AIR SYSTEM of clear quality regular goods at each by this serial number,merchandise management is done and a guarantee of quality for six months.
Notice there are so many copy products same as our design.
all copy products has no tested same as us.
[h=3]
[/h]
K&N filter is recyclable with cleaning and it can make possible long life works.
A filter washer can cleaning the dirt in filter without damaging the cotton of material.
After perfect cleaning it can make same as new filter performance.
And it not giving out unnecessary waste and the exhaust gas examination at the time of equipped with K&N filter,because regulation is cleared in every country in the world.so you can also use the high owner of environmental consciousness in comfort.
Sims77
18 May 2013
Staffordshire
Lol
When I fitted mine it was like building Lego on Christmas morning. A lot of head scratching
