mint
- 18 March 2007
- Age
- 40
- Asakusa, Tokyo
- www.JDMtas.com
Ok This started on saturday.
Suspension wise im running Driftworks Coilovers (Not that low bit stiff all round)
APEX Rear Tie Bar
Thats it.
Now, i kept hearing a 'knock' noise on the rear pass side of the car. Was the kinda noise of a wheel hitting the arch. Its not tho as its not anywhere near low enough or soft enough to allow that much play.
This only started after i had the car up on stands for the last 4 days or so.
The whole exhaust system was off. The wheels were off, I then raised the car on the rear about an inch and a half and stiffen'd up around 2 clicks on the back.
So.. this noise, I drove to dundee yesterday and when there i jacked up the car and checked the coilover. The spring was loose (a few mm of play) So tightened up all the collars as they came loose. Thinking that would be the problem.. moved away and its still knocking. Any speeds if you hit a pot hole or bump etc. Mostly on right hand turns..
So.. had another look half way home. The rear ARB bushing is a bit fooked tbh.. thinking it could be this. All the bushing for the exhaust were off and re-fitted.. the system had some play.
So.. i softed the coilovers off back around 5-6 clicks and still the noise happened. When i got to Aberdeen it seemed it was getting louder but not sure. I just went out now to have a further look before i order up some new ARB's etc and the exhaust had ALOT of play, standing at the back of the car.. the backbox could move to the left a good few inch's and it would hit off something. However to the right it only took about half an inch and it was knocking off the rear ARB. So iv added additional cable tie's and the system is now SOLID.
So.. I'll drive it to work in an hour and see if the noise has now gone.. If not, I'll order a new ARB or some bushing. Anyone else got any ideas on what it could be? Bearing in mind it only just started and only work being done back there was raising the car and taking the exhaust off.
Also.. do the uk s14's have the same ARB? Same bushing for it? Is it an over the counter part? If so.. does anyone know a part number? Should i just get a new ARB anyway?
Thanks.
APEX Rear Tie Bar
Thats it.
Thanks.
