I have needed to sort a front mount for quite a while now as my car is running over 1 bar on the wing mount which must be pretty much the limit for that.
But I really don't know which one to go for at the moment,have been reading up loads on the different types and if I am honest am now more confused and really could use some help.
The main ones I am looking at are
Autobahn88 is a tube and fin design,same size as the japspeed ,has low pressure drop and is a really good fit and has all aluminium piping
http://www.jperformance.co.uk/autob...det-front-mount-intercooler-kit-fm-p-172.html
Japspeed is bar and plate also low pressure drop and aluminium piping for better heat resistance
oh and the apex too
http://www.japspeed.co.uk/product.asp?P_ID=361&strPageHistory=related
http://www.apexperformance.co.uk/ca...36&PHPSESSID=0a9da9f7d3f893b76a318b455da46adb
I have tried to find a definitive answer on which set up is best but had no luck really everyone says differently,apparently the tube and fin cools better and allows the rad to work better but because of the design is weaker and more prone to leaking,and damage. Bar and plate the way I see it is more suited to track work
My car is going to be mainly used on road so would I be better off with the autobahn or the japspeed? Any advice would be much appreciated!
Thanks
Chris
oh and the apex too
Thanks
Chris
