- 20 October 2006
- Age
- 48
- Poole Dorset
- www.gtiroc.com
OKies, you may have read about my small non starting issue but after alot of testing today the car is finally back up and running, altho, be it slightly bodged :rotfl::rotfl:.
The non start appears to be down to the ECM relay wiring. For those that down know, thats the relay that sit behing the ECU. Anyways, the relay itself works fine, however, for some reason, when the igntion is switched on the relay wont engage to complete the required circuits. A temp fix involving some looped wired has done the trick for now but obviously i need to find out why the relay isnt getting power...
Wiring diagram time...
What I need to know is, what and where is the car are the bits in the red box in the above pic? What ever that is, including the the wiring from the fuse box back through the loom is likeley to be the cause. Specifically the W/B (White / Black) one.
So, before I go on a loom removal journey, anyone got any ideas?
Cheers
J.
Cheers
J.
