GUEST_JDM
when the car starts from cold it almost stalls (the idle jumps up and down from 300 to 600 rpm) after about 20 seconds it returns to normal cold start.
once temp guage reads middle, the car idles massive lumpy cam style as i have NO cams this is not good!( jumps from 800 down to 600 almost stalls then back up to 800 then normal for 30 seconds maybe then back through the cycle) driving around and booting it there is no problem seems to be fine apart from the extreem richness lol
ive checked near everything ive replaced every vacum hose n line, checked for any leaks in my cooler pipes, replaced my oxy sensor which helped a small amount,
im looking at now the air flow meter now
if any one has had this before or could send me in the right direction that would be good, ive also put the car on a carman scanner to check for any sensor faults but everything came up fine
cheers jared
cheers jared
