I need help :(
5 September 2006
Malaysia,Sabah
Do you guys have difficulty to start your engine while the engine is still warm? I have this problem and i live in a warm country. Any one can help me out? is this normal? :(
5 September 2006
Malaysia,Sabah
i just change my spark plug last year. It is NGK Iridium range 6. I don't have any problem when cold start. Is it because the valve selonoid?
5 September 2006
Malaysia,Sabah
I only refill when it almost finish. Is already been a month like this :( the engine sounds like not enough fuel go through and i don't smell any fuel too. I don't have any great technician here to help me check. So sad T_T
gunner93
Try switching on for about 30 sec to get your fuel pump up to pressure, then do your cranking ...
7 January 2007
Perth, Wait Awhile
KK too many rotaries pro... but should have one or two sr20 pro
Did it happen just recently or used to be like that all the while? Did u change anything before this happens?
5 September 2006
Malaysia,Sabah
I tried before about 30sec to start up but still the same. When i do about 2 to 3 times to start only can run the engine.
It happen recently. So far I didn't change anything,only standard upgrade.Yah, have few pro here, i did bring to them for checkup, but what they told me is normal. Headache XD
OK, few other things:
Check the connectors to the two temperature sensors. If they're fine, a sensor could have gone. One provides a temp feed to the ECU (the other to the temp gauge). If its not working, the ECU will think the engine is cold and set fuelling accordingly. This would cause hot start problems.
After that, a failing fuel pump or coilpacks/PTU.
5 September 2006
Malaysia,Sabah
I read the user manual book, it say not to step accelerator while to start your engine. But i did once XD it can start hehehe... after i read that i don't do it again. Check the connectors of two temperature sensors hmm... i will try check that. I will let you guys know. Anyway thanks alot for your help.Really appreciate
5 September 2006
Malaysia,Sabah
I have check every connector, everything is fine. Nicely, do you mean the engine coolant temperature? How can i check the sensor still working fine or not?
Yes, the coolant temp. Not entirely sure how you'd check. I expect the reading via Consult would be from the relevant sensor though. Its not necessarily that though. Its just a prime suspect.
5 September 2006
Malaysia,Sabah
Nicely you are right! I did the Consult check today. The coolant temperature sensor is gone. After replace everything back to normal. Thanks for your information Nicely and everyone too. :D
gunner93
Glad its sorted out. :thumbs: BTW, where did you do your Consult check?
Just in case anyone didn't know, you can buy Consult interfaces for laptops from these guys. They also, very helpfully, provide a circuit diagram in case you want to make one yourself :) It doesn't do everything the full Consult will, but it'll do real time monitoring, diagnostics, error reading, error resets, ECU reset, etc. I can also highly recommend spending the very small amount on the Nissan Datascan software. Don't copy it, please. Its well worth the small fee, and you'll get free updates. :)
I have one of these (a batch were made by one of the SXOC guys) and have it permanently wired to my Consult plug :)
