How do i replace this plastic triangle part?
18 August 2009
how do i get the plastic triangle out from the corner of the door? mine is cracked and i have a replacement but not sure how to get it out!
5 July 2006
London
if there's no obvious screws or anything, it's probably just held in with clips and should pull off. I haven't removed one, but that would be my guess :thumbs:
18 August 2009
im sure someone has? i could just try prying it out as its going in the bin but id rather do it right :)
the top bit tucks into the moudling as you can just see in the pic, the bottom tucks into the door skin
Its just held in by plastic moulded plugs. You just need to get a srewdriver in a corner and it will pop off. Its a bit like the door trim clips
