In the UK now and ready to be collected.. (postage is an option)
looking for - 950.00 GBP
GT-RS specs..
Output - 400ps
Compressor Wheel - Trim 52 / Inducer 51.2mm / Major 71.1mm
Compressor Housing - Inlet 60mm / Outlet 50mm / AR .60
Turbine Wheel - Trim 76 / Major 53.8mm / Exducer 47mm
Exhaust Housing - Inlet Flange GT25 / Outlet flange Internal-GT25 / AR .64
What HKS say about the GT-RS..
HKS GT Ball-Bearing Sport Turbo Upgrades are bolt-on turbo upgrade kits for factory turbo-charged vehicles. These kits consist of new, larger HKS GT turbos designed to bolt directly on to the stock manifold(s). HKS GT Sport Turbos are designed and sized to promote maximum power and response for maximum airflow throughout the RPM band. From the HKS precision cast turbine and compressor housings to the specially designed blades, each turbo is crafted to provide high levels of performance and quality.
GT-RS specs..
Output - 400ps
