- 14 April 2007
- Shropshire, UK
- www.lupix.co.uk
Ok folks,
I've always wondered how the metal subframe collars were fitted to an S15 so when I did mine the other day with a mate, I took the chance to take pics so hopefully, those who wanna give this a go will know it's not too difficult. I purchased my set of subframe alloy collars from Driftworks
Jack the car up and get the rear section on axle stands. Then ensure you put a jack underneath the diff centrally.
Well first pic below shows what the stock subframe front bush looks like when the nut and bracket holding it in place is removed from underneath:
Basically there are two front subframe mounting points (where the rear suspension bolts to) and two rear mounting points (more central and closer to rear of diff). We got to work by loosening all the nuts/bolts for the brackets on the front mounting points so there's enough room to prise the subframe and bush down so the top collars can be slipped in place. Don't remove these nuts/bolts entirely in case the subframe might fall off!! Well, we were paranoid about this anyway :wack:
As above pic shows, use 14mm socket to loosen the bolts that hold the bracket to the sides of the car and a 17mm socket to loosen the main nut which holds the bracket to the subframe etc. Do this for both sides of the front subframe mounting points. At this point you must ensure the diff is still being firmly propped up by a jack (as mentioned at beginning). Once all nuts/bolts are loosened then VERY SLOWLY drop the jack holding the diff. Only by a couple of centimetres. It's unlikely the subframe will drop cos of the bushes so use a pry bar to prise the subframe downwards - on both sides. You should then have a gap that's big enough to slot the top collars like so:
Next to finish off the front mounting points by fitting the bottom collars (completely circular collars without the cut-out section) jack the diff up so it should then move the subframe back up and leave you more thread to get the bottom collars underneath the existing bushes. Then completely remove the nuts/bolts for the bracket, slot in the bottom collars and then put brackets back on underneath:
If you have the same issue as my bottom collars then this is a real tight fit which means they don't go on flush against the stock bush. So get another jack and force the bracket to be pushed against the new collar plus bush etc until it's all nice and flush - sorted!!
Tighten all the nuts/bolts for brackets and the front subframe is now completed. Moving onto the rear mounting points, these are not as fiddly because there is no bracket. So again, with the car on axle stands and separate jack holding diff, take off the brace (or whatever it's called) that joins the two rear mounting bushes for the subframe. Once this brace is removed, put the original nuts back on the threads - in case the subframe might drop out (but it shouldn't!!). Once the nuts are in place, drop the jack a few centimetres and then with pry bar, prise downwards the bushes so there's enough of a gap to slip in the top collars like before. Then jack the diff up again and fit the bottom collars, put the brace back on, nuts back on and it's all finally done!!
I'm hoping I got everything right but please feel free to comment/correct.
Nice1 - J
BTW - I know the underneath of my car doesn't look as nice as Dean's and yes, it really needs a good session of jetwash and underseal!!
Nice1 - J
