Gtx3071r
15 April 2014
Sydney
Hey gents
Any body tried the new gtx3071r on their SR ?
4 August 2011
That's a serious turbo :nod: Would require a forged engine and decent fueling to make the most of it but would be amazing once done :D
drifter
4 April 2011
Norfolk
I'm running one on mine, with the right supporting mods it'll push over 500bhp :)
15 April 2014
Sydney
Have you touched engine internals or just standard supporting mods man ?
And when does it hit boost ?
15 April 2014
Sydney
Nice build man :)
Bet she's a lot of fun
Was the tial housing a T2 or did you have to take the T3 path ?
drifter
4 April 2011
Norfolk
The tial housing is all v band, no normal flange connections.
Daveizz
28 April 2012
Netherlands
SR20 can only take up 400bhp on OEM internals, everything above means changing the internals, at least the spings and valves.
But better taking a stroker or Forged engine
ive got a forged engine that will be going into the 180 can you "drifter" tell me you thoughts on cams and this turbo... its for a drift application
I have a few mates with the GTX, their setups are all E85 projects with built motors, most are aiming for 350kw's on 30psi give or take a few psi
drifter
4 April 2011
Norfolk
I've only ever used it with Tomei Procam 270's to be honest. When it first went on I had the old style Greddy plenum and standard sprockets and it didn't produce what I was expecting, only 440bhp and wouldn't respond to more boost or timing.
I then fitted Tomei adjustable pulleys and the new Greddy shortport and it made all the difference, engine seemed more balanced an pushed out 507bhp :)
There's another user Actual_Ben_Taylor on the SXOC also running this setup with a couple of small differences and he's nearly topped 530bhp :)
As for the response, my graph is linked to on the first page, I upped the limit to 8000rpm to help keep the power range in play. Dropping the cam size would help spool, but I'd be cautious of going too mild, maybe to a Procam 260?
B
BenTaylor200
527fwhp with 2.0l bottom end, haven't ran it up with the new 2.2 setup.
I also had the Tomei 270 Procams, but I'm going to be switching to the Kelford 188-B with a set of custom DLC coated rocker arms...
cheers for that mate, you answer another one of my questions about intake manifolds while you were at it. so either a 260 - 270... mid range response for sliding..
